Water leak under the sill drivers side close to the rear wheel anybody hsve any ideas to what it might be
Glasgow14
Wales
Mercedes e250 coupe 2012
I have a leak from the sill under the car close to the rear wheel anyone have an idea what it might be
Do you have a sunroof?
Hello and welcome.
Is the boot space dry under the carpet/lining ? Does it have any kind of Body kit on it , AMG ? for example ? .
Is it a 207 coupe by any chance??
If so they have drain grommets along the sill and these have small holes in them and they block up so what I would do is undo the screw at the back of the sill just before the wheel and pull back you should be able to see a grommet remove this and the park the car on an incline and watch the river come out
With the grommit I'd put a big hole in it so water escapes out easier
You will know if the sill has water in it if you accelerate and brake you will hear a sloushing noise
