D
Deleted member 173561
Guest
Hi, some advice please.
I recently replaced my C class W204 coolant thermostat after getting a P0128 code. First drive after change, got a coolant leak from the water pump. Water pump was not leaking before at all (no coolant low warnings etc) so presume changing thermostat has somehow caused water pump to leak? Anyone had this issue or could explain if they are related at all. Thanks
