It looks to be well cared for and, at 2000 miles per year, hardly used.and 80K miles from new
I tried petrol, acetone, paint thinner etc
Something loose in the boot or under the boot floor?Perhaps someone can adise me or point me somewhere. The only issue on the car is that there is a random clunk from the rear? It happens usually when I drive down my drive or on a flat road. It does not happen on rough roads very much at all. I have changed all the mountings, the spheres, the links, the roll bar mountings, the diff mountings and the subframe mountings. I find no movement in the prop shaft connectors and the fuel tank has nothing loose inside. I cannot think of anything else to change! Any ideas? Driving me mad..
Spare wheel, tools, jack etc?Perhaps someone can adise me or point me somewhere. The only issue on the car is that there is a random clunk from the rear? It happens usually when I drive down my drive or on a flat road. It does not happen on rough roads very much at all. I have changed all the mountings, the spheres, the links, the roll bar mountings, the diff mountings and the subframe mountings. I find no movement in the prop shaft connectors and the fuel tank has nothing loose inside. I cannot think of anything else to change! Any ideas? Driving me mad..
Mounts are new, the jack and spare removed and the exhaust is perfect..I am at my wits end especially since it is random. I have tried loading it to the gills and sat in the back to try to locate it by ear. I had thought a spring light be broken though I can see no evidence and it is such low mileage it is unlikely. All very odd. I will no doubt turn out to be something idiotic though I have had it over a pit with a crowbar and nothing moves and the MOT finds nothing loose eitherSpare wheel, tools, jack etc?
Exhaust loose/moving on mountings, hitting the body etc?
Engine mounts could be worn causing exhaust to move.
All guesswork of course, any decent MB specialist should be able to find it.
Lovely car, btw Maybe some before/after pics of the engine bay. Do you plan on having it retreated once clean?
I forgot to take before pictures but basically everything you will see in the future 'after' pictures used to be black!Spare wheel, tools, jack etc?
