callummac92
Hi all,
I have recently replaced the pump after noticing i was getting little pressure from it on the front. i had already read through various threads and tried everything before hand (cleaned nozzles, ran through with warm water etc) Ive ran the new pump without the nozzles connected (just from pipe) and the pressure is still really poor. I disconnected the pipe from the pump altogether and i really think i should be getting more pressure than i am. The back windscreen washer seems to be ok oddly. I tried swapping the hoses over and still had the issue on the front.
Other than buying a new nozzle assembly I'm really at a loose end here so any help will be appreciated.
thanks
thanks
