Weird C Class Alarm Issue
havoc1
UK
C32 AMG Estate
Hi, checked search but this one seems different to other problems noted.
Last Tuesday night at 4am the indicators on the car started flashing - no alarm sound. Turned it off with fob.
Today, the alarm started sounding with no indicators....turned it off again OK.
It's a 2003 C32 AMG Estate.
Anyone had this double issue before? Any fix?
cheers
Normal faults with these alarms is a faulty alarm siren, the back-up battery goes U/S.
If you get it on STAR (MB diagnostic computer) it should confirm this.
I believe it is in the region of £80 from MB, and is fitted under the N/S wing, behind the front bumper.
Mine has been doing very similar for the last week on a 53 reg W203 coupe
In with a local Indi today for a replacement Siren (as confirmed by STAR) for a little under £80 for the unit, then half an hour to fit.
+1 for alarm siren diagnosis. £70 incl VAT for latest version from MB, I got one about a month ago, and spent an hour fitting it. Tamper proof torx set required.
EDIT: Or unplug it for free :) (obviously the siren will no longer work)
I have the same problem as havok1. Thanks for the info andy
when i bought my 203 the alarm siren didnt sound,i found the earth wire on the inner wing had been cut i reconnected it and all was fine,i dont know why but it still working 18 months later
