My local fitter (and also a good friend) fitted this into my dad's 52 C Class.
He doesn't and hasn't ever had a CD changer fitted (in case it has a bearing). We used the D2B fibre loom that came with the kit and all initially looked good.
On initial power up the ipod worked a treat, however, when you then turn the ignition on and back off there is no audio, everything else works, i.e. skipping tracks etc. In order for the audio to work again you have to press the reset button for the Dension, trouble is as soon as the ignition is 'recycled' same happens
Ideas anyone?
Ideas anyone?
