- Jan 3, 2013
- AUDI S8 V10, S210 E320 CDI (R.I.P.)
So after finding a small leak I decided to investigate and found it to be a core/freeze plug. Ordered from MB and proceeded to remove the front cat, exhaust manifold and turbo. A few manifold studs came out as the nuts seized.
Plug was tapped from one side but would not flip so drilled a small hole and got it out.
Studs that came out were cleaned and 'double nut'd' back into the engine block. The new plug arrives so I put it all back together bar the air intake system so I can check for leaks.
Car takes an unusual large amount of coolant and when I start the car boom, oil shoots through the top breather, up the dipstick and makes a right mess. Dipstick full of coolant.
Before I strip and scrap it, where have I caused the damage? Is there anything behind the exhaust manifold studs or have I hit a jacket with the drill? I am interested from a mechanical point of view as to what has happened.
P.S. W210 parts for sale soon
