Benz17
Hi All,
I have a conundrum, for which am hoping you guys and girls could help me with. I currently have a 2017 E350d. Since i purchased the E350d the third service A was due and was done at an indy in July 2020 cost as follows
Standard A Service
Engine Oil
Oil Filter
Air Filters
Fuel Filter
Cost for above £410 inc, and all original Mercedes parts. Would you all think this is a reasonable price for a London indy.
I was under the impression that a ATF oil change is due for this vehicle at 5yr or 77500 miles, and therefore looked into a service plan, as mercedes were offering 20% discount last year on paying up front service plan, so i took this plan, 3 services being B A B cost £1200, (£400 for each services), and under the impression that when it was time for the A service ATF oil change would be due, as that would be the 5th year, also having mobilo for the next 3 years was also appealing.
I am now led to believe and ESS confirms that for the 2017 E350d is only due a ATF oil change at 77500, and not at 5 years or 77500, bearing in mind i purchased the plan so i could get a brake fluid change in the B service this year, and ATF in the A in 2022, and brake fluid again at B in 2023, as ATF wont be due, do i continue with the plan, or should i cancel and get a refund, as i have not used the plan yet, and continue using the Indy, not sure if he would still be cheaper then the service plan with the brake fluid change due.
Have to add not too fussed with having full MB service history, as i keep my cars for around 8 years, and the indy does log the service on the Mercedes system and has star.
Would appreciate your thoughts and advice on the above.
Standard A Service
Engine Oil
Oil Filter
Air Filters
Fuel Filter
