no because the actual noseweight would be 75kg, not 25kg. Of course, if you removed the bikes you would need to put some weight back on.
The caravan would need to be balanced to a noseweight of 25 kg, which would be unstable. Hanging some bikes on the back of the car (on the towbar or anywhere else) wouldn't change that.
If the bikes were mounted on the front of the caravan it would be OK, but you'd need to move some major items around to keep the noseweight to 75 kg. For one thing this might not be achievable, and for another you could easily create a 'dumbell' setup with heavy weights at front and back ... which is potentially dangerous. And you'd have to re-balance if you towed with less (or no) bikes next time. Not ideal.
