What Do I Need
pepper&boulou
EastKilbride
Volkswagen Passat V6TDi estate
As already mentioned on a previous post I had enquired if anybody knew where the oil cooler should go. i received 2 responces thank you . the general consensus was that it should be mounted under the radiator which unfortunately is no good as it hangs too low. I now need further info and to help I have attached a pic of the oilcooler which came from a smashed 1993 300D and I would like to retro fit it to my 1988 300D. So I need the following info please. :D
1/ where should this oil cooler be mounted and how do i acchieve this there are no fittings with the oil cooler (tried it under the radiator, not enough ground clearance)
2/What is needed to fit it to my merc( which has never had an oil cooler)
3/ where do the hoses connect to (the hoses are very short)
Any help with the above will be gratefully received :o And thanks in advance
can you give me the first 6 digits of your chassis?
i cant find a rad that looks like that in the epc...
locations i have found... under left headlight, side of rad, on top of rad...
