LaMondain
- Sep 17, 2020
- Location
- Serbia
- C 220 CDI, W204, year 2008. (Engine OM646, 125 kW)
I'm preparing for the transmission flush on my C220 cdi 2008 with my local indy who's never done it before so it will be our first time. I've watched quite a few videos and being the idealist I'd like to do it in the best possible way so to maximize the amount of the old fluid drained before adding a new one in order to make the mixing ratio as high as possible in favor of the new fluid. I run across this video at 10:48min and I'm curious what do you guys think about it? I guess he's feeding the transmission through the fluid filter hole, using that thick striped hose? Do you see any benefits/shortcomings in comparison to a more common way of doing it through a cooler return line?
Besides, would inserting fluid under pressure through a cooler return line (on the transmission side) do any good? Would it flush the Torque Converter without starting the car or the fluid would just drop down towards the pan?
