What Engine is this? I was told 240D
cdc02254
Broadstairs
1979 W123 240D-1983 W123 230e
Umm, went to get new filters, glow plugs etc today but when I looked at them none of them fit. So what engine is this then?.
http://img687.imageshack.us/img687/4524/cimg0005u.jpg
It certainly looks like a 4cyl diesel to me, and if it is, the engine number should start : OM616.....
Where did you get the parts from?
I went to Southern Motor Factors to get the parts.
I had either a large diameter air filter or flat air filter.
Fuel filter was about 300mm long and oil filter small. They also gave me a primary fuel filter which I couldn't see on the car but assume it should be before the fuel filter. I need to get a manual.
As above, what's the engine number??
Sorry my mistake, you are right its a pneumatic governor IP.
This might explain why the exhaust has been bodged onto the engine manifold. Would a W123 exhaust go onto this engine or an W115 exhaust go onto the W123 car?.
Whare would I get parts and a manual for this engine?
Engine Update :-
Engine number 61601108001ME
