what is a block heater on W124?
Discussion in 'Engine' started by tpv01, Jul 21, 2008.
  1. tpv01
    tpv01 Hardcore MB Enthusiast
    174
    Jul 9, 2008
  2. Number_Cruncher
    Number_Cruncher Hardcore MB Enthusiast
    987
    Jan 14, 2008
    Midlands
    Car:
    1995 E300D
    Looks tempting doesn't it?
    When you look under the exhaust manifold, you probably won't find the heater, but you'll find a large blanking plug instead. This plug is in TIGHT. There are tales of people cracking the block while trying to undo it!
    If you do want to pre-heat, it's probably better to use something that plumbs into the bottom hose. I think they're made by Kenlowe.
  3. BTB 500
    BTB 500 MB Club Veteran
    18,737
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    They are used in very cold climates to stop the cylinder block from freezing and potentially cracking ... many car parks in Canada (for example) have sockets to connect up to when you park.
    As mentioned you can get pre-heaters made by companies like Kenlowe that are slightly different - they normally heat the water and circulate it round via a pump. A gadget-mad friend of mine had one fitted to his Espace. The advantage is much faster warmup, better economy from cold, quicker heating/demisting, etc. But not really justified in the UK climate.
    I believe some emergency vehicles have them, so they can be driven hard straight from the garage (fire engines etc.).
  4. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    I think you are thinking of the much older 5 cylinder 3.0 diesel with a steel plug near the front of the block.
    That plug is the standard position for the block drain and it will come out no problem.
    and, yes it is tempting..
  5. Number_Cruncher
    987
    Jan 14, 2008
    Midlands
    Car:
    1995 E300D
    No, well at least not on my OM606 anyway. It's adjacent to the standard block drain, near the back of the engine.
  6. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Ah, yes. You're correct. I can see the drain next to it on further inspection.
    I can't find a part number for the heater, do you know it by any chance.?
  7. grober
    grober MB Club Veteran
    27,615
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  8. Number_Cruncher
    987
    Jan 14, 2008
    Midlands
    Car:
    1995 E300D
Tags:
Share This Page
