Well now you know too .Of course you do, that was never in doubt!!
You still , for the purposes of the driving test , have to use the hand/parking brake when coming to a halt , it is a fault not to . This is regardless of manual/automatic .
I used to fail people on advanced tests if they failed to use it . If you wanted a class 1 pass you even had to apply it between stopping and selecting reverse , before parking . These were the guidelines .
It is also illegal to leave the vehicle without ‘setting the brake’ .
Wow, there’s really nothing you’re not an expert on.
So at the end of test, you just stopped, and used to footbrake until you switched off the engine, got out, locked the car and walked away?
When did you take your test - 1920???
Might be worth you reading the Highway Code, specifically rule 123. You know, just in case you have to take a retest in your dotage...
The Highway Code - General rules, techniques and advice for all drivers and riders (103 to 158) - Guidance - GOV.UK
Signals, stopping procedures, lighting, control of the vehicle, speed limits, stopping distances, lines and lane markings and multi-lane carriageways, smoking, mobile phones and sat nav.www.gov.uk
Not sure why it matters when I did my test, but as you brought it I’m 99% sure I did my test more recently than you... being in my 20’s...
If you think engaging your parking brake more often makes you a superior driver then well done... that’s great.
I’ve witnessed plenty of driving tests pre-covid (as a passenger) where friends and family who wished to take the exam in an auto have used my car. At the end of the test they simply stop, put the car into park and the examiner goes through the results. Not once has the examiner mentioned them not applying the foot-brake at the end. Had it been a manual left in neutral and it started moving forwards then yes I’m sure it would be mentioned...
I’m sure you’ll now go on to say that you know better than the various driver examiners, or that you’re a senior driving examiner yourself. Which is also great.
It is a minor fault , do it once or twice ( on the DOT test ) and you might get away with it , do it consistently through the test and you will fail . Simple as . Do it on an advanced test , you certainly won’t get a Class One , and will probably fail ."Using the handbrake incorrectly
As the safest thing to do, candidates often feel they’ll be penalised for not using the handbrake at every opportunity during their test. This isn’t always the case.
While the handbrake should always be applied while parked – and putting the handbrake on in most situations will make the car more secure when stopped – you won’t fail for leaving it off, providing it doesn’t affect the vehicle and cause it to roll backwards or forwards."
Point #5 here-
9 misconceptions about the UK driving test
I will fail if I stall on test! Really? Is that True?www.drivingcrawley.co.uk
That is because the law does not specify which device is used , merely that you must ‘set the brake’ . As long as the car is secured against rolling away , it does not matter whether it is a frictional brake or a mechanical lock on the transmission . If the candidate did neither they would not only fail but they would be guilty of an offence .If you think engaging your parking brake more often makes you a superior driver then well done... that’s great.
Well , I HAVE been to the examiners training centre at Cardington , as a guest of two friends who are qualified DVSA examiners , where , before they get to conduct examinations , candidates must first attain a standard very similar to police advanced level , which I was trained to , and then beyond to instructor level so that I could train others to become IAM and LSD ( now ROSPA ) instructors , and am still current as an emergency response driver with the Fire Service , so I am very familiar with the standard required .If you think engaging your parking brake more often makes you a superior driver then well done... that’s great.
Spot on , I don’t routinely apply the brake every time either , particularly if I know I’m moving off after that one car on the roundabout , but more usually I will time my approach to keep moving smoothly , without needing to stop .none of that - I’m just aware of the Highway Code rules, and what I was taught for my standard and IAM tests. Other IAM instructors here have said the same..
when you have sat in on a test, the examinee has left the engine idling unnecessarily at the r d while the result is scored and still passed?
and no I don’t always follow the dictate but that is a personal choice based on the circumstances, much like exceeding a speed limit.
in summary - use it or lose it.. your choice...
I've never known one to fail, it's just scaremongering.Which auto transmission has a plastic pawl mechanism for park? I'm happy to be educated. So what is the "park" position for then, if it's not to hold the vehicle stationary when parked? A manual transmission doesn't have this feature? I am in the camp of just selecting "P" on both my car & van when parked up. I will use the handbrake as a back up should I park on a hill of any gradient. And I do use the handbrake occasionally anyway to stop it seizing as I'm aware of it needing to work for the MOT. The amount of cars I see pull up in American movies / TV programmes & the car lurches back or forward a couple of inches as they let off the brake because they've left it just in "Park" means I'm not on my own
When am I reading these posts, why do I hear in my head a nasal whiney voice?
Well , it does have to meet a measured standard of efficiency on each wheel ; there used to be a rule about the number of ‘clicks’ on the ratchet were permitted before travel was excessive , but that I believe was done away with ; but it still must be able to hold the car on a hill or stop it in an emergency.When am I reading these posts, why do I hear in my head a nasal whiney voice?
Op, the parking brake these days on modern cars is just something that the mot tester has to tick off on a box to show its working, if it doesn't it fails. Thats it.
Strictly , a manual transmission does have that feature ; if on a gradient you select whichever lowest gear would cause the vehicle to move uphill : this is the ‘parking gear’Which auto transmission has a plastic pawl mechanism for park? I'm happy to be educated. So what is the "park" position for then, if it's not to hold the vehicle stationary when parked? A manual transmission doesn't have this feature? I am in the camp of just selecting "P" on both my car & van when parked up. I will use the handbrake as a back up should I park on a hill of any gradient. And I do use the handbrake occasionally anyway to stop it seizing as I'm aware of it needing to work for the MOT. The amount of cars I see pull up in American movies / TV programmes & the car lurches back or forward a couple of inches as they let off the brake because they've left it just in "Park" means I'm not on my own
Unless it was a rare two stroke motor, in which case it wouldn't have enough compression to hold it.Strictly , a manual transmission does have that feature ; if on a gradient you select whichever lowest gear would cause the vehicle to move uphill : this is the ‘parking gear’
I don’t know if there is a ratchet mechanism in electrically actuated parking brakes , or some other method of holding the brake on once set , but regardless of that the brake must still hold fast so that the car will not run away .electronic buttons don't have measurable clicks
