hi guys.
if water gets into the cabin of a 124 cabin, and its under the foam of the main carpet, then where does it drain down to.
ie what is the main drain path for water from the cabin..
i know its not the 4 corner drains with the little angle spouts.
between the floor area and the undercarriage, is there a cavity that water can store in? if so, how does one get it out?
after my leak, i know there is light moisture under the rear drivers side carpet, and the sponge feels slightly damp, and thus i think has absorbed water.
The next step if to see where the water from the rear foot well drains down to.
its not the normal 4 corner drains, so is there any drain points in the middle of the underside?
can water get retained between the floor and the undercarriage?
i need to ensure that all areas are checked thoroughly!!
cheers
cheers
