I believe this is the Intercooler Circuit Overflow Reservoir.
It is separate from the engine coolant expansion bottle which is located on the opposite side on the engine bay.
It allows the coolant to expand... the Intercooler has it's own liquid cooling system.
Mercedes W205 2015.
I've found a bottle which seems to be empty and have no idea what it's for. Last time I've checked all fluids, there was some pink fluid there but now it's completely empty.
Does anyone know what that is?
Thanks a lot.
Hi,Good evening good people ... I have the same problem on my c250, and adding water to the cold van starts to fail and just stepping deep into the accelerator is back to normal ... in a workshop they could have cracked the intercooler ouu with some leak ... does anyone have any news on the subject? best regards
Did you find a problem?I also have this issue. Mine is using about 1 litre of water every 400miles.
Did you find a problem?Did you find out the issue mate? I’m having the exact same issue and at cold the pipes connected around the intercooler circuit reseviour has pressurised hoses,
Any idea what was the cause of fluid loss?
