what oil for my car ?
2003-c180kcoupe
c180k coupe
which oil do i need for my c180k coupe ?
is it mb 229.5 ? and not sure wether it should be 5w-30 , 0w-40 etc ?
thanks
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
st4
Banned
In the driving seat
C220cdi tourer
0W-40 would be better if you can get hold of it, retaining more fluidity when cold and more viscosity when warm
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
some people would say that car should use 10w40
horgantrevor
its a 1.8 engine not a 5.5 amg 0w40 is not a good move for that engine its like water i use it in the c36 and 5w40 in the c240 v6 and any 1.8 i ever had got 10w40
markjay
MB Master
London
MB Dealers in the past used Castrol 5W-30 and then Shell Helix Ultra 5W-40 on my 180k, both 229.5 - if this helps you make up your mind.
(I believe that Olly PCS (BlacklC55) used Petronas Syntium 3000 5W-30, though I am not sure)
OP
OP
2
2003-c180kcoupe
c180k coupe
for the first 3 services that were done by mercedes it says they used mobil , the last one it doesn't say .
it needs a 1 litre top up , is it ok to mix different oils as I've no idea what was put in on the last service and the next ones not for another 6000 miles
markjay
MB Master
London
Yes, it is OK to mix different oils.
It is generally not recommended but it is better to have two different 229.5 oils then too little oil...
But don't top it up if it's on the Min level, only if under (when hot).
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
It will probably be Mobil 1 then. 0w40 229.5
OP
OP
2
2003-c180kcoupe
c180k coupe
i will check again tomorrow , the car park at work is totally level
the last service wasn't done by mercedes but hopefully they used the same oil
st4
Banned
In the driving seat
C220cdi tourer
The 0w means its much more fluid, means from cold, the engine is better protected, the 40 means even when hot, the engine is still well lubricated
Car Bibles : The Engine Oil Bible
Mobil1 0W40 is okay, because the '40' denotes that it's actually thick enough at temperature to work. 0W20 just doesn't get that viscous!
