darkchild101
- Mar 27, 2013
- Mercedes C250TD
Copied from the Alloy wheels direct.net website.
" The alloy wheels for the Mercedes 202 series use a PCD5x112, centre bore 66.5mm and M12x1.5 bolt thread"
So how about the length
The shank length should be 26mm (50mm total length)
Your dealer should be able to supply the correct bolts, but if not Alloywheels Direct.net sell them.
Was thinking more of flea bay not the dealer:bannana:
If you go the eBay route, ensure that the bolts have the correct radius head and are not tapered. I made that mistake and had to return them.
darkchild101 said:Anything that is rigt type here please c class M12x1.5 | eBay
