What Springs ???
proser
Stafford
W210 E320Cdi Estate
looking here it mentions that to get the right springs
"IN ORDER TO DETERMINE THE REAR SPRINGS THE POINTS LISTED IN THEFOLLOWING TABLE FOR THE RESPECTIVE MODEL AND THE INSTALLED CUSTOMIZED VERSION ARE TO BE ADDED UP"
But for the life of me I can't seem to get it to work.
Can anybody help
I have the following options:
auto trans
memory seats
electric seats
high capacity battery
sound system
trailer coupling
Give the VIN number to a Mercedes dealer, they will then know the springs. Or your springs are colour coded, so look carefully and you will see the blocks of colour about halfway up. I couldn't see them on mine, so the VIN was used.
I just want to know how it's worked out.
I need to lower it after fitting 18" and I have found out that I can only go down one size on the shims and I don't think that will be enough; as I was hoping of 2 sizes :( So will probably have to go for Avangarde springs
Why do you need to lower it? For cosmetic reasons?
To work it out you need the values attributed to each element. The dealer has the table.
Ant photos of the car with new wheels?
Yes, it just looks like it has too much gap between the tyres and the arches.
But need to change the spec of the rears as I have fitted a tow bar and tow a large twin axle caravan
To work it out you need the values attributed to each element. The dealer has the table.?
The table is in the link, but still can't work it out :wallbash:
Will sort out over the weekend/next week when I am off.
Start with a baseline figure of 74 for the fronts and 58 for the rears, then add on the options numbers.
FOR SELF LEVELING CODE 480 TABLE
Total points rear spring pad
-19 210 324 31 04 210 325 01 84
20-25 210 324 31 04 210 325 02 84
26-31 210 324 31 04 210 325 03 84
32-37 210 324 31 04 210 325 04 84
38-44 202 324 17 04 210 325 01 84
45-50 202 324 17 04 210 325 02 84
51-57 202 324 17 04 210 325 03 84
58- 202 324 17 04 210 325 04 84
Does this help explain?
