What tyres for a standerd vito van?
Flying start
Vito
Hi all what tyres are you fitting to the vitos
Looks like my o/s/f has scrubbed off on the inside
Is there a a tyre that most people fit ? It's just got the standerd steel rims think there 15"-16"?? It's got hankook fitted at the moment well I think that's what there called.. Any one revamped me some I know most people will all have there own choice
Giantvanman
Essex
FFRR 4.4 TDV8 Autobiography
Continental Vanco 2 for me. I would have the tracking checked too.
OP
OP
F
Flying start
Vito
Thanks guys will check them out
The tracking is the next thing on my list when I bought the van it needed a n/s/f tyre would this make my steering wheel sit off center or would it just be the tracking corseing it?
What milage are you guys getting out of the conti tyres?
BTB 500
MB Club Veteran
Berkshire
R129 SL500, W639 Vito 120, S205 C300
I'm getting close to 30k miles per set. They wear on the outside edges, particularly at the front (both sides, but n/s worse). I swap them front to back to get longer life.
It's a known issue with the 639, you could possibly get the geometry changed at the front but I'm pretty happy with the handling so I put up with the tyre wear :)
I have started running higher tyre pressures now to see if that helps at all.
OP
OP
F
Flying start
Vito
Thanks for the info guys, got a lad at work to sort the tracking he said the tow was a mile out its straightened out the steering wheel Witch was annoying,
Been advised to get my o/s/f tyre changed as it's scrubbed off and at its legal limit.
Thanks agin
jimfred
Barnsley Yorkshire
2012 Sport X- 2013 113
Our work van has the 3200kg weight variant, runs around normally at about 3000kg, did 36k on original tyres. Only conti vanco as original were available for size/weight required, a bit pricey but couldn't grumble at the milage. I do swop them around about every 8 k miles as it does scuff front near side.
