It sounds like your asking which wire feeds the reverse lights at the rear cluster.
I've always used Chinese Android units that provide the feed from the HU so haven't needed to tap into the feed there. As I'm running the co ax front to back it's no extra work to include the feed, that more often is incorporated into the co ax anyway.
But if I'm right in what you're asking,
use a meter reading 12 volts, push a pin through the wire insulation and measure to ground while the reverse is selected (with ignition on, which would be needed to select anyway).
