jonnyboy
- Nov 27, 2005
- Location
- Camberley, Surrey
- 1991 sl300-24 project,s124 280,w115 no interior, w108 project no engine
hi all.
As some of you will know I bought a project r129 300sl 24v a few weeks back with a suspect head gasket amongst other things. The car came with a head set in the boot and some stem seals. Ive done 3 head gaskets in the last 4 years but had very little to do with twin cam engines. The car has done around 136k miles, doesnt seem to overheat, and as yet I don't know if it uses any oil or water as I've only done 5 or 6 miles. Its symptoms were rough running and being hiccy and farty.
I have the chance of a local to me engine and box from, i think, a member who wants £300 for them, but there was no significant testing of the engine prior removal as the car was bought as a donor and immediately scrapped.
I have a competitively-priced labour quote to do the gasket, inevitably these things usually lead to more parts along the way and I have an inherent need to keep costs low and do as much as I can myself.
These are the compression test figures I did last night:-
Cylinder Dry Figure Wet Figure
1 15.5 16.25
2 16.25 17.00
3 12.25 13.00
4 12.75 13.25
5 13.25 14.25
6 15.5 15.75
Figures are in bar, the wet figure is the same test with a few drops of oil dropped into the bores (to temporarily seal worn rings). The top breather is a bit oily. There is no significant rattlyness from the top end. No back pressure to speak of so hopefully the valves and guides are ok. I am sourcing a header tank "sniffer" although struggling at under £85 right now. Tried a header tank "bubble test" in the meantime which was inconclusive as I kept getting spill-over out of the header tank with no bubbling at all .
Plugs weren't too bad, none rusty, or wet:-
IMG00020-20090903-2027.jpg picture by entire54321 - Photobucket
Sorry for the long post guys.
Interested to know who would do what, and if anyone has done an m104 twincam, how bad it was etc?
1 15.5 16.25
2 16.25 17.00
3 12.25 13.00
4 12.75 13.25
5 13.25 14.25
6 15.5 15.75
