What's the possibility of putting a C32 or SLK32 engine into W208 Chassis?
I quite like Superchargers and I really like my 320 CLK so whats the main issues with putting this engine into my car?
All i'm really after is what do I need to know about getting it into the car and running as per O.E Mercedes fitment, is it worth it, why not just buy a C32 all miss the point but if you hold this view and know something which may be of help please don't be put off by my comment, more info will be welcomed!
From my research on the idea getting an AMG ECU into the car is the only real 'big' thing that needs solving...
My reasoning is the SLK32 engine was offered in the same suite of engines my CLK had so if they are of the same vintage and use the same 'Language' to talk to the other systems such as autobox, dash clocks and alarm/immobilzers you should be able to fit a slk32 ECU to a CLK if you know the pinouts and can match them up....
what say you all?
what say you all?
