Wheel Alignment - is this correct info?
MrLCA
Stevenage
2011 C250 CDI
Afternoon all,
Just a quick one. I've ordered my new tyres to be fitted tomorrow through black circles. Thought I'd give the garage a call just to as if they could fit me in for a 4 wheel alignment. I mentioned that I have a C-class (w204 c250 CDI)
They said that they couldn't do it because they don't have a Romess machine and apparently anyone claiming that can do it wouldn't be doing it properly and it has to go to Merc?
Now I've never heard of this before and done a bit of googling and looks like a machine to set ride height? Isn't this to do with air suspension?
Any insights please guys?
Ta.
OP
OP
MrLCA
MrLCA
Stevenage
2011 C250 CDI
Is there a high Street brand that you know of with said alignment tool? Tyrepros, kwikfit etc?
Benz17
London
E350d AMG (W213)
Wheels-in-Motion at Amersham are well regarded by many on this Forum.
Yep I also second wheels in motion, used them for my previous W211, and my current W213, they know how to set up the mercs, they are an hours drive for me, but worth the drive.
Bobby Dazzler
MB Club Veteran
Mittel England
ML AMG-line Black Series
Kwik Fit have Hunter Hawk Eye.
I had the wheel alignment adjust one one of our cars today. My preferred place couldn’t get the system to recognise the car, and Hunter still hadn’t responded to their query after 2 weeks so I took it elsewhere.
My preference would be to go to Wheels in Motion, but that’s a trek too far for me. My criteria was somewhere with a Hunter Hawk Eye, was not a nationwide chain, and which looked like a “professional” set up.
Petrol Pete
Petrol stations ...everywhere
C55 AMG Wagon
A Kwik Fit near me has a Hunter HE and can do 4 wheel alignment , not near the OP's location . OP Just phone around your local tyre depots , you might find one with the right kit.
OP
OP
MrLCA
MrLCA
Stevenage
2011 C250 CDI
Wheels in motion is not that far from where I work so will give them a call tomorrow. No prices on their website. Any ideas on rough worst case scenario?
MrGreedy
Midlands
w212 E350 CDI 125th Anniversary Edition
I could guess it would be in the £100-500+ range, depending on what needs to be adjusted.
If alignment is basically there when they check, I would expect the bottom end of the price.
If it needs new parts, e.g. adjustable camber or whatever bolts, then there's the cost of those, plus fitting and then fiddling around setting it up. As a premier alignment specialist, I think it would be reasonable to charge in the £100-200 an hour region. So the most simple outcome would be the lower end, and well, the sky's the limit depending on what you want or need doing.
As you suggest, a call will be best bet for a better guide, but it won't be £40 for a quick volume based chain garage job. And a good thing too
Bobby Dazzler
MB Club Veteran
Mittel England
For reference, today I had a four wheel alignment in the Midlands it was free to check, and then adjustments were charged by axle if required.
It was £54 including VAT per axle. My car only need to be adjusted at the front - the rear was within specification - so I just paid £54 to check four wheels and adjust two.
The place I originally intended to use charges £72 to check and any adjustments are included.
I expect Wheels in Motion to charge more. A similar place - Centre of Gravity - quoted me £375 but I’m sure would have been next level given their attention to detail.
merc estate
C Class w205 220d AMG Premium line 2016
Do you have the tyres fitted after wheel alignment ?as the car has to settle or tyres first then take back a couple of days later ? i'm just trying to make things more complicated.
bolidemichael
SW20
S211 E500
C of G has a super reputation with Porsche aficionados but they are next level, from what I understand. You don't need the level of set up they offer for your vehicle.
WiM is excellent and the initial set up cost me about £170 with or without VAT, I don't recall. However, they do say that quality is remembered long after cost has been forgotten. In my case, the cost was increased because of the supply of eccentric bolts required in order to adjust the castor. They are official MB parts though and this is the difference that they offer, where other conventional alignment places with a hunter won't have the adjustment available.
ash1212002
Which place was this in the Midlands?
Martin 1
Northants
'05 CLK 200 auto Convertible. silver with blue hood.
Hi, £50 to £80, any more they're crooks.
MrGreedy
Midlands
Okay, so how much is a set of adjustable bolts to allow proper setup of the wheel alignment?
And then existing bolts might be siezed/difficult to get out.
And then there is the training and equipment costs to cover.
So, from £50, just how much profit are they making from the job, and how long do you think all of that will take?
Hah! you got me. It was a good wind up 👍 :cool:
Bobby Dazzler
MB Club Veteran
Mittel England
Yes, it was through Porsche circles that I first came across them. Very impressive service but not for the average road car, and not for the average budget!
ToeKnee
leicestershire
R230 SL500 in teal blue, R231 SL500 in black. Vauxhall insignia diesel
Had mine done on a hunter machine early this year in Hinckley at an independent tyre fitters, was quoted £76 to do the job but only the rears needed doing so they only charged me £38. Were very professional and took good care of my SL and I could see everything that was being done through a large viewing window.
OP
OP
MrLCA
MrLCA
Stevenage
2011 C250 CDI
Just getting my tyres fitted now.
Thought I'd give them another chance as I can see the Hawkeye machine in their workshop and they may have misunderstood me on the phone yesterday.
Nope, can't (won't) do it because it needs Romess machine.
Phoned another local, trusted tyre place and have it booked in with them in an hour's time.
Maybe these guys don't need the work?
