I had this report yesterday on the alignment of my 2007 E 320CDi. This is the after report.
The technician was able to adjust the toe to get everything lined up (which was my original request due to having a ball joint replaced a while ago with the result that the steering wheel wasn't centred any more.)
However, it appears that the camber is out all over and he wasn't sure why this would be. He had even rung Mercedes to check these figures as he was concerned about them.
Car has had an easy life with no known damage issues with 60k on the clock - its been in the family since new.
Car has passed an MOT at Mercedes within the last two weeks and has also been looked at by a local garage for a slight grumbling from the front left hand side when turning right, from which no obvious fault could be discerned, other than "possibly" noise from the steering rack, but no obvious suspension issues. (Not conclusive, but basically the suspension is not about to fall apart)
Thoughts I've had
1) Its measured against the wrong spec and is in fact ok.
2) Suspension parts are worn all over and needs a complete rebuild!
3) Springs have gone soft resulting in everything sagging
What I don't know is if these numbers are wildly outside any sensible range, and what are the likely consequences of it?
Any comments?
Thoughts I've had
Any comments?
