Can anyone tell me what length wheel bolts I would need in order fit a set of staggered 18 inch AMG wheels to a W202. The standard bolts are 12x1.5 radius 40mm and they are too long, about 6mm to long.
I bought some 30mm long ones as i couldn't find 35mm long ones and they seem too short, 3.5 turns and its tight, I dont feel this is safe.
Now, i found a place which sells 35mm long bolts but I just want to double check to see if this fits perfectly.
So what are the correct length Bolts I should be using?
Also, It's going on a elegance, therefore I think there's quite a bit of clearance in the arches, Should I lower it or not? if so, which coil springs are best for looks without giving a ride too harsh?
