Hi All,
Long time lurker, first time poster.
I purchased a 2010 E350 Coupe, came with a lovely set of aftermarket staggered 19" alloys. Life was good.
The wheel bolts are rusty so I decided to change them, they are Mercedes OEM radius bolts (28mm).
However, I noticed the alloys actually take tapered bolts, presuming the previous keeper was being cheap and lazy, I purchased some 28mm tapered bolts.
The problem...........
The front passenger side changed fine, all new bolts torqued to 110.
The front driver side refuse to torque. They get a little tight but just turn and turn.
I put the oem back in and they torque just fine.
There is a few mm difference in length due to the radius v taper.
I am at a loss as to why one side works and the other doesn't. If it was a stripped hub then surely the OEM wouldn't tighten either.
All help and thoughts appreciated.
