Haris
- Jul 13, 2010
Elitecarcare is another online car care retailer you can try
Having my alloys refurbished, and so I'm keen to keep 'em tip top once back on the car. Thinking of applying a sealant. Two spring to mind:
1. Autoglym Alloy Wheel Seal - I like Autoglym stuff and it seems easy to apply being an aerosol.
Get pics of the III's up
Looks like they did a good job on those rims
How much bobby, if i may ask ?
I think the give away that it's not the original factory finish is: (i) the shine is too deep and glossy; and (ii) the finish has too much glitter.
ok thanks
what sequence are you going to be using for that prep work, ie what polish wax etc, cause it is something i should consider
Spent the early evening sat on the lawn polishing the new AMG III with Autoglym Ultra Deep Shine and then a coat of Extra Gloss Protection.
The 'Ask an expert' section of the Autoglym website suggests that EGP should only be used with SRP, as it's not designed to work with UDS. I didn't have enough SRP so I thought I'd test it - came out fine.
Did you specify a different paint finish to the original factory finish that contained the extra glitter?
Dee
