D
Deleted member 134751
Guest
On my 2012 W204 I am receiving yellow warning lights on the dashboard indicating issues relating to ABS/TPMS/EBD and cruise control is inoperative. Apart from that, it seems to drive ok.
I scanned it with my iCarsoft and it gives me the following codes (the descriptions next to each code are just what I've found on other forums via Google because the iCarsoft said "The fault code is not found in the database" for each one - so the explanations below might be not be correct):
C200100 ?
C326600 Consequential fault
C113200 ?
C112200 Front Right Sensor Battery Voltage Low
C327000 Implausible values of rpm sensors on rear axle
C120000 The power supply for component 'B64/1(Brake vaccum sensor)' is not OK.
My question is, does this look like a wheel sensor issue? And could it also be related to low battery / voltage? Obviously with lockdown, the car has not had much use and certainly not many long runs.
One of the error codes appears to be "Front Right Sensor Battery Voltage Low" - do sensors have their own little batteries or would this be referring to the main car battery?
Any idea of what to expect from a main dealer in terms of cost for replacing a wheel sensor?
And does anyone have any idea what 2 of the above fault codes mean?
Thanks!
C200100 ?
C113200 ?
Thanks!
