cheers boss.
think ill get them ebay
im guessing most will fit ?
Be careful to squeeze in the metal ring on the back of the cap in so it goes into the hole in the wheel. If you are a bit hamfisted, the plastic lugs will break off the back holding that metal ring on.
Otherwise, fit as Abb above says.
True story ^
There is another type that just has plastic clips without the wire spring. They seem to be secure enough though.
SET OF 4 BLUE MERCEDES ALLOY WHEEL CENTRE CAPS 75MM FITS A B C E S ML CLASS NEW | eBay
markjay said:Saw this: https://www.amazon.co.uk/gp/aw/d/B0183TKE3W/ The photo shows original MB caps with the correct MB part number (this the part number for my 2013 car). The price for a set if 4 is less than what one cap costs at the dealer (~£15).
