Where can I get?
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
spark plug leads that are made up for a specific length say twice the length for a W202?
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
Perhaps Jimmy could sort you out K. ? He seems to have spark plug related kit to deliver in his 'C' estate most days.
S.
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
HT leads............you name we got it or can make it.;)
I could custom make any lead set you like to any length or pattern. Could even make it in a snazzy colour, I think we have some red, blue and yellow cable at the moment besides the standard black.
We have some very 'pretty' leads coming soon for Corsa's, Saxo's etc.:bannana: :bannana: :bannana:
Seriously though, I can make just about any type of lead set you want.
BTW, has'nt yours got DI (direct or semi direct ignition)? Mine hasn't got a lead set as such, two plugs have coils directly on them and two short leads going to the other plugs.
Steve_Perry
Wales, U.K.
:cool: :bannana: :bannana: :bannana: :bannana: :bannana: :bannana: :bannana: :bannana: :cool:
Do you do requests... Would you do vivianite green cables? hehe j/k The top of my motor is all covered anyway, so no cables to see.
S.
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
oh look what I found out ;)
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
they unscrew ;)
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
...on both sides!!!
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
what do ya rekon then Jimmy? do you think you can make me the wire terminated with the 2 brass conectors as shown in the pics? I will re-use the plug ends :)
jimmy
Northamptonshire
I could do that...................but I won't!!!
I would only supply a complete set with new ends as the ends breakdown, deteriorate and are prone to arcing too.:confused:
Don't worry they wont be very expensive at all. you will have to let me know what lengths you want each lead or are they all the same?
I will look for some blue cable so it will match the rest of the engine bay.:cool: Can't promise that though.;)
jimmy
Northamptonshire
Forgot to metion....
A tip for measuring the length of cable is to use a piece of string and route it roughly where the leads would go, measure from the top of the plug boot to the top of the other boot, where the cable goes into the boot. I can work out the extra bits that go into the boots.;)
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
okey dokey! be sure to use the most expensive wire you can find ! :p
So I take it the ends wont be OEM mb parts then?
jimmy
Northamptonshire
I will have to check but I think the screw connectors on the end of the leads would be compatible with your existing boots if you wanted to re-use them. The boots that I would supply with the leads would not be OE, but just as good........I would say that though wouldn't I!:D
Our supplier for some of the boots also supplies Ford but has to grind the Ford logo off every one that he supplies us!!!!!!:crazy:
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
Ok i'll post the size up 1st thing in morn, just got so busy with cleaning car etc, then had to pick my mum up and it was raining, all that hard work!!!
at least it got the salt of ;)
mike c200
Netherlands
c200 esprit
All parts from that wire can be orderd by mercedes :)
wire A 110 159 18 18
smal pics on the wire A 000 159 14 38
Greetingz,
Mike
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
its one thing ordering a wire/connector piece and its another thing having a crimp tool - I make cables at work all the time from BNC, End type, ethernet, fibre......
It's all very well having the parts but trying to crimp with cr@p tools or wrong tools and especially not having experince in terminating a cable then forget it!
jimmy you got a PM.
jimmy
Northamptonshire
I shall speak to my technical department tomorrow, in other words I dunno.
We do sell cable to a local MB specialist who buys OE ends and makes up his own leads, I shall speak to him too.
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
excellent! you have the sizes you need in the PM! :)
I must be your most akward customer!
jimmy
Northamptonshire
Pain in the a$$:p
OP
OP
Koolvin
Koolvin
Administrator
Staff member
Staines
W168, W169 & S202
The valve cover is on!
The whole engine VALVE cover was replaced (rocker cover) along with the cover plate that covers the spark plugs ALA 'Kompressor' oh and a new rubber gasket!
As you can see the HT leads (spark plug cables) were too short but Jimmy has made me some custom leads to my measurements and to OEM spec ;)
left is old cover with the indentation for the old pipe to the inlet manifold...
right is new cover ;)
the spark plug leads: MB rock!
it can be unscrewed ;)
closeup:
this morning I will be fitted my new leads! thanks Jimmy! I was able to keep the OEM plugs but the silicone cable was custom made by Jimmy at a special price ;)
Oh thanks for the wipers for the squeaky bubble car! - there on, dunno if its sqeaking yet!!
The valve cover had a few scratches on but V12 told me it would but you cant go wrong for 30 quid can ya?
So Mark300SL's Idea, V12's breakers for the Valve covers, and Jimmy for the custom HT leads - without the help of people from this board this mod could never of happened!
