Where can the fault be?
goldenii68
London
c230 elegance selection kompressor
Help!!
My bulb failure indicator lamp came on last night, I have checked all the bulbs and all seem to be working ok, it also came on today when I had no lights on, all 3 brake lights appear to be working, the light doesn't come when I start the car, it comes on only when I'm driving so 'where can the fault be ?':dk:
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Wait until the warning appears again and check all bulbs. Remember the rear sidelights have two per side.
OP
OP
G
goldenii68
London
Will do, if its not the rear sidelights, where next to check?
BlackC55
Check the correct wattage of all the bulbs. It will probably be the rear bulbs though.
OP
OP
G
goldenii68
London
I forgot to say I've got led sidelights and numberplate lights, both sets appear to be working ok, they are the error free canbus ones, you dont think however ......?
OP
OP
G
goldenii68
London
Even if they are working and had them for about 5-6 months ( and made sure they were the canbus error free ones) and they were off when the light came on today .........?
OP
OP
G
goldenii68
London
Oi, this is serious, it weeks to sort out my ESP/BAS light and open walet surgery to boot, I have precious little hair to pull as it is, I can't bear any warning lights coming up:eek: (its not a dig just lighthearted banter:D)
OP
OP
G
goldenii68
London
Me too, nothing more annoying than a niggle in your pride and joy you can't sort quickly! :wallbash:
GP801
Sussex and Tuscany
2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
Bulb does not have to have blown. The system will pick up a bulb in imminent danger of failing. I think it measures change in resistance. One is probably about to go - usually a rear sidelight or brake light.
OP
OP
G
goldenii68
London
Wow! In my c200 when that light came up, it was normally a brake light one that had failed, best get some of both types soon :thumb:
