Hi all & thanks in advance for your help.
car is S211 from 2007 (wdb2112081b081152)
I have a strange problem, usually MB owners complain about Suspensions go all the way down (LEAKING), in my case rear Suspension won't come down, so when car not loaded the height is Normal (around 36 CM), also when car loaded the the air-pump works and adjusts the height. the problem starts when car unloaded, it seems the air won't release from the struts (both left & right).
car only level itself beck to normal (36 cm) after I turn off the engine.
So I replaced the Relay (A002 542 72 19) but to no avail.
I found what I thought is (Suspension Height Level Sensor) mounted over the rear sweybar (A 010 542 77 17), but after some research I am now confused whether this sensor is for Suspension Height Level OR Headlight Levelling?
