jshodgson
i want to clean my MAF and failing that replace it. The MAF must be in or near the air filter boxes I guess but which side and how do I get to it?
Are the sensors beneath the two plugs that are sticking up in the pic?
What is the challenge with cleaning? Is it access or does cleaning not tend to work on these? And if I need new ones would I be better looking for a salvaged bat wing?Theres 2 . In the bat wing . Good luck trying to clean them. Replacements run into the hundreds.
Thanks. Before I begin on this is there anything else that could be causing my weird pulsing/hunting engine at low revs (1400-1700). It does it when I hold the revs but only if the car is moving. If the engine goes into limp mode it doesn’t do it.
