Where is the mass air flow sensor / MAF? Pic attached
mercedesc180a
C180 (2006)
I have a C180 Kompressor 2006
I have the check engine light code P0171, system too lean bank.
Someone suggested cleaning the MAF sensor and I have the correct cleaning spray to do this, BUT I am unsure where it is and how to disconnect it! Sorry if thats a basic question. I have watched a youtube video of it being removed on another type of Merc but the layout seems different on mine.
Pic at
where is it?? :( And also, I heard i could avoid removing whole air filter box etc by just living cover off and spraying the cleaner through to the maf sensor that way?
Hope someone can help.
You can see the plug just to the right of the yellow sticker on the airbox.
My money is on you having a split breather hose under the airbox itself, air mass never go on this engine, plus you have a lean fault as its sucking in unmetered air.
