- Oct 4, 2019
- Location
- Guildford
- E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
Ah well I do have a removable tow bar fitted so that could be a good lead! Inside was clean - that’s a really good point because if it was a drain you would think there would be residue of whatever was draining in the blocked teat.The hole in the ‘teat’ looks rather large for a cable supplying a light on the vehicle, which makes me think of either a tow bar 7 or 13 pin cable, (although 53mm is a bit small for a tow bar socket) or a mains cable for a lead lamp?
is the inside clean or dirty? If the latter it could be a drain plug, such as in the boot floor.
Nothing to do with straws, is it, as that’s what I appear to be clutching at here....
