So I bought my CL55 AMG almost 5 years ago, I knew it was clocked when I had bought it and at the time it had done over 170k miles (I know this as it had full mbsh up until about 6 months before I bought it and the last service it recieved was at 161k).
I have since covered around 50k miles and other than regular oil changes and fixing the odd broken thing I've not done much to it, at well over 200k miles it's still going strong but could do with some love so.....
Recently when changing the ABC pump, one of the brackets broke off the timing case cover, this called for the timing case cover to come off and be replaced so in the process I have changed:
The timing cover
The water pump
The belt tensioner
ABC PUMP rebuilt
Cam covers resealed as they were leaking oil anyway
New oil vapour pipes
While the timing and cam covers were off we had a **** it moment and decided to take the heads off, and change the head gaskets and spark plugs while we were there!
The bit that broke off the timing case:
First cam cover off:
Timing cover off:
So here is the first head after a bit of a clean up, spark plugs will be a lot easier to install like this ....
More pics in the coming days as I progress!
The timing cover
The water pump
The belt tensioner
ABC PUMP rebuilt
Timing cover off:
