No. Didn't ever have the light, but I was on 125k miles so I went to Keighley West Yorks to a specialist chap who replaced it along with motor and gearbox oil for I think £250. 200 miles round trip, but hundreds of pounds cheaper than most places and highly recommended.did you end up with the low oil pressure warning too ? the one where if you catch it quick enough you just replace the o ring on the pick up or where they leave it to late and replace the engine ...
Have you looked at Volvos ?So I’m thinking of an E Class, the main reason being space. Mondeos and Insignias are also on the list, I’m after boot space rear legroom and comfort
budget is around 4k
at the moment I’m looking at a low spec 220s212 and a high spec 320 s211, mileages are similar
given the choice which would you go for ? The 320 is 2007, the 220 is 2011
646 in the 211 yes, 651 in the 212 debatable.The 220 is a bombproof engine
The 651 is a great engine, does have a few common issues but they aren’t as common as the internet would have you believe.651 in the 212 debatable
An engine with a single row chain tucked away at the back and a plastic water pump just can’t register as bombproof to me! I’m sure it’s a genius design for accountants wanting to shove the same engine in 20 different models without modification.The 651 is a great engine, does have a few common issues but they aren’t as common as the internet would have you believe.
