Which fuse for windscreen washer pump?
Nibbo
Gloucestershire
C180K Estate
Does anyone know which fuse I need to check for the windscreen washer pump?
According to the sheet in the fuse box it says 'Windscreen washer pump' and where the fuse number would normally be it says 'electronic'...
What does this mean? :confused:
Also, in case it is not a fuse; does anyone know where the pump itself is?
I assume it is stuck to the fluid container and can be accessed by removing the wheel arch lining? :dk:
Any help greatly appreciated as always.
