Which Gasket Set? W166 Oil 2012 Bluetec Oil Cooler Seal Replacement
Lucio
Windsor
ML350 bluetec
Morning All;
Moving to my next job, replacing the seals on the W166 oil cooler, as it is leaking.
I’ve done a lot o reading on this topic, basically the job is simple but to get to it, you need to remove most of everything that is seating on the top of the engine! That means new gasket and seals every where!
Whilst searching the topic i found it very difficult to identify the gasket/seals part numbers for this job, but i have encountered the complete engine gasket, do you know if the following kit is going to have all that I need to complete this job pls?
Dichtungsvollsatz, Motor AJUSA 51042500 ohne Zylinderkopfdichtung — Jetzt kaufen!
Thank you
Lucio
