uumode
- Sep 1, 2003
- C300 AMG Line Premium Plus
The Mercedes manual gives two methods to check oil level.
1. When engine is cold (my usual method because it's easier to remove the oil cap and top up if necessary). Or has been started temporarily wait 30 mins.
2. When engine is hot at normal operating temperature, stop engine and wait 5 mins to take reading off dip stick (didn't do this method as on my previous cars the oil cap expands with the heat and is difficult to get off when hot to top up)
I took a reading cold, and discovered the oil level at min and figured my new car was consuming oil as expected and indicated in the manual. So I topped up the oil to the max line on the assumption it would consume more oil as the engine was being run in.
Then the other day I wondered what the level was and the engine was hot, so waited 10 mins to take a reading, and was surprised it was about 5-6 mm above the max line.
I was concerned of overfill complications (which may or may not be real at 5-6 mill above) and syphoned off a little excess.
I took a fresh cold reading and the oil was just past halfway on the dipstick.
Then warmed up the engine to normal temperature, waited 15 mins and the reading was just below max which I feel more comfortable with.
But which is the true reading?
