Which oil and where from?
Discussion in 'Engine' started by mr. shr, Sep 22, 2011.
  1. mr. shr
    mr. shr MB Enthusiast
    1,879
    Apr 22, 2004
    Guys, my Mum's 211 is due an E+ service and indy wants 250 just to replace oil and filters.
    I'm thinking I can do those jobs for a lot less than that.
    But which brand of oil should I use and where is best place to buy from?
    Opie oils suggests the car needs 5w 40.
    Helfrauds suggests 5w 40 for their own brand stuff and 10w 40 for Castrol or Mobile.
    Car is 2002 W211 2.6ltr petrol v6 (112.913)
    Is Costco still a good place to buy oil from?
    Any pointers would be most helpful.
  2. markjay
    markjay MB Club Veteran
    24,931
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    You can't go wrong with Mobil-1 from Tesco. Best oil for best price...
    But E+ service is more than just an oil and filter change, there are many other checks that needs to be carried out, plus you should also consider other 'additional items' - ATF change, brake fluid change, coolant change (if applicable), fuel filter change, air filter change, cabin filter(s) change, spark plug change (if petrol), etc.
    And... the stamp in the book....
  3. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    Yep, I realise this is a biggie and was put off by the £250 just for oil change and filters.
    Would do spark plugs myself too but will ask indy to do the brake fluid change as he has the high pressure gizzmo for doing SBC brakes.
    But thing is, I did all the MB service items on my W202 last summer (spark plugs, fuel filter etc) but didn't notice one jot of difference in the car's running.
    I just wonder if some of these items do actually need changing every two/four years or if it's just MB over egging it a bit.
    Car probably does 5k miles per annum (if that).
  4. markjay
    24,931
    Jun 24, 2008
    London
    Car:
    I think that's the whole point of preventative maintenance, i.e. not to allow the car's performance to deteriorate. Leave these service items in place for longer, and then you will notice a difference when you finally do replace them...but that would be fire-fighting, not proper maintenance.
    For example, while I do agree that the air and fuel filters will not disintegrate at precisely 4 years plus one day, they will eventually get clogged-up, with obvious adverse affect on the car's performance. So changing them in good time is very sensible. Besides, the cost of the filters is really negligible when taken over a 4 year period, so ignoring these is definitely false economy.
    1 person likes this.
  5. ihandyman
    ihandyman New Member
    26
    Sep 17, 2011
    Se1
    Car:
    w202 c200
    That is a very good advice!!!
    I intend to do all the work myself and save lots of money by changing all the fluids and filters etc. And the car works like new ! I also change the oil every 5k M and touch wood so far so good and !
    So yes you better prevent then to be sorry ;)
  6. ML-Simon
    ML-Simon New Member
    17
    Sep 19, 2011
    Car:
    ML 270 cdi
    Costco is good and most fully synthetic oils for the correct spec will do. The number one thing to do is change the oil when needed over any types or make of oil.
    I would question Mobil 1 being the best but it is very good and unless you have a race car it will more than do the job.
  7. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    Update:
    OK so I've ordered the bits to do the service on my Mum's 211.
    I can get this oil quite cheap. Would it be ok? Says it's 229.3 spec which is what that engine needs. Any good, or must I insist on the branded stuff?
  8. silver_star
    silver_star Active Member
    212
    Dec 10, 2010
    Leicestershire, England, 3rd Rock From The Sun
    Car:
    W203 C220CDI Auto Elegance
    How cheap is "quite cheap" ?
  9. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    About fifty quid for 8 ltrs.
  10. silver_star
    212
    Dec 10, 2010
    Car:
    That's not cheap in my book when you can pick Mobil One up for £28 for 5 ltrs.
  11. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    Hmmmm just been doing a bit of googling and it isn't that cheap.
    Where can I get Mobil 1 for £28 please? Opie?
    Edit:
    Just seen it on Opie.
  12. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    So is the Comma stuff no good then?
    Any experience with it?
  13. silver_star
    212
    Dec 10, 2010
    Car:
    There is nothing wrong with the Comma oil. Its just that you can get better oils for your money.
    Costco sell Mobil for £28. I have also heard that Halfords can match it if you ask....how true this is I don't know.
    Another alternative would be this stuff: GM 5W-30 DEXOS 2 FULLY SUPER SYNTHETIC LONGLIFE OIL 10L | eBay
  14. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    Thanks for this.
    Think I'll pop down to Hellfrauds in a bit to see what they're offering.
  15. BillyW124
    BillyW124 MB Enthusiast
    2,890
    Oct 22, 2010
    North West London
    Car:
    W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
    Why dont you go on to the Eurocar parts website, choose the oil you want and see what you get with MBclub uk member discount.
  16. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    Good plan.
    Just tried it and there's a nice discount indeed. Does it only apply to online or can you do it for collection too?
  17. BillyW124
    2,890
    Oct 22, 2010
    North West London
    Car:
    its online, but you can click and collect from your nearest ECP.
  18. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    The stuff I was going to get (Castrol Edge 5w30) is out of stock locally.
    Not coming up with any Mobil oil.
  19. OP
    OP
    mr. shr
    1,879
    Apr 22, 2004
    OK went with Shell Helix from Euro Car Parts in the end. Got the discount so thanks for pointing that out to me.
    You don't actually have to prove you're a member of MB Cub or anything. Just use the code and away you go. They told me that there are several car clubs they give discounts to.
    But it seems you don't have to be a member of any the forums to get the discount. As long as you know the discount code, then anyone can get it. :dk:
  20. markjay
    24,931
    Jun 24, 2008
    London
    Car:
    That's the current offering from Costco, both are 229.2/229.5 (but not 229.51):
    [​IMG]
Tags:
Share This Page
