Which oil do you use in your m271 engine and which one is recommend ? Been told mobil 1 0w 40 is too thin for m271 hence bit of clicking and clatter on cold starts as it leaks out of the tappet valves overnight. So when the engine is started in the morning the valves have to repressurise therefore the clicking. Does this seem about right?
Would 5w 40 shell helix be a good alternative ?
