So doing the ATF service.
Carried out the procedure of filling the sump with 7L of oil.
Had the car running for around 30 mins.
iCarsoft was showing 45 degrees while the infrared thermometer was showing around 32 degrees.
So who do I trust? Where does the iCarsoft get its reading from. Like, where is the transmission temperature sensor?
Problem is when I went to drain the excess hardly anything came out.
When draining the origional fluid I managed to spill some so not exactally sure how much came out.
Advice, experiences, tips etc would be much appreciated
Thanks.
Thanks.
