gadget1960
Hi to all, hoping to get some ideas as to what the Whining noise is coming from the front of my W210 e240 2.6 V6 motor is, When running it sounds almost exactly like the belt whine you get from a supercharged motor and increases in pitch with raising the RPM, all of the ancilliary wheels ie: P/S pump, water pump, alternater, and spring loaded tensioner etc: all seem to be operating / rotating freely, no fluid leaks etc:
the belt seems to look ok with no visible cracks but does have a few light score lines on the out side of the belt and has obviously been fitted for a while.
Do you think a belt change would be in order? as I have heard that a worn belt does tend to make strange noises when a little worn!
Any advice / ideas?
Any advice / ideas?
