Whirring noise when fan on
Discussion in 'Electronics' started by Murphyslaw, Apr 15, 2011.
  1. Murphyslaw
    Murphyslaw Member
    47
    Feb 17, 2011
    Car:
    2002 Mercedes E270 CDI, 2010 Toyota RAV4 XTR
    When my W211 has the fan on (irrespective of whether the aircon is on or not - and I know the aircon is on even when turned off), I get a whirring noise which sounds like the transmission is straining under revs. When I turn the fan off altogether, the noise disappears (even when driving normally).
    Is this the aircon pump on its way out? If not, is there a quick/cheap fix?
  2. SKIPPERDOG
    SKIPPERDOG Member
    57
    Feb 14, 2011
    dublin
    Car:
    211 320cdi
    it sounds like the blower motor is noisey make sure you've no water leaks onto the motor check the carpets next time rains the water drains get blocked on the 211's the water would cause the motor 2 get noisey,ive replaced a few for that problem
Share This Page
