What year is your W202 C230K? Assuming this is the car that you want ivory dials fitted to. Depending on your model year there are two routes open to you.
If you have a pre model update car (around 1997 I think) then you will have to look at after market dials and find a place that can fit them to your instrument cluster (or fit yourself ).
If your car is built after '97 then the sport models came fitted with ivory dials and you could do a straight swap for a whole new sports model dash cluster.
Below is a pic of my dials
Also if you do a search on the whole forum you will see that this topic has been discussed at great length before, so there will be useful info there too.
*EDIT* You might get a better response if this was posted in the electrical section too I'm sure a friendly mod will move the post across.
Originally posted by Steve_Perry *EDIT* You might get a better response if this was posted in the electrical section too I'm sure a friendly mod will move the post across.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
