I have a 2008 Vito 115 CDI. I had a problem about 6 months ago with positive crank pressure, that turned out to be the PCV or oil catcher that needed to be replaced, and its been fine since.
However, last night I had a real problem with oil spraying out of the dip stick, which i hoped would simply be the PCV, oil catcher or the breather pipe that was blocked. I got the van recovered home and today I checked them and they all appear to be fine. I then ran the van with the breather pipe disconnected from the PCV valve, and white / grey smoke floods out of the PCV where the breather pipe should be connected. I will try to upload a video of the breather smoking.
The exhaust gas appears to a bit black, but not blue.
Any suggestions?
Any suggestions?
