Re: dash backlights not working
after reading someone in the same predicament my last hope is the red fuse on the back of the cluster. After lifting the carpet, trim etc. I can’t find the white Speedo cable, which is described as a thin white cable clipped to the lower steering column. However, there is a fat black cable (a cable inside a rubber hose shroud) exiting to the left into the transmission tunnel, when I moved the cluster it moved too, so its probably the one, but there’s no free play in it, I was going to detach it from underneath the car and I found to my horror a large plastic aerodynamic shield covering the belly of the car, so it looks like I’ll have to remove the trim >above< the cluster…or find someone with ultra-skinny hands and arms?
BTW when I removed the lower trim to check out the headlamp dial assembly I found I could insert my fingers in the upper gap and push out the instrument cluster, a worthwhile thing if you can't remove it with hooks.
