Gazwould
The reason your mpg is unchanged is because the area of the map used for typical road-load and torque demand (acceleration) operation is unchanged. Plus at normal road load, cars need remarkably little power to drive along, eg at a steady 60mph, a typical car only needs about 15-20hp (12-15kW).
Remapping to use more aggressive settings for areas of the operating envelope where higher load and torque demand are called for increases emissions. This results in much higher emissions during this style of operation. Effectively this is what some of the OEMs may have done under the dieselgate scandal, which has subsequently been highlighted by using a more strenuous drive cycle.
If you think your remapped cars are not making more emissions, think again.
FWIW remapping should be illegal in my opinion, though of course I recognise that it currently isn’t.
Your car, your choice, other people’s lungs.
For the most part I'm requesting an upchange because the engine can pootle along happily at silly low rpm with light throttle due to the increased torque .
The early upchange request can happen 1100 - 1400 rpm .
I can't see this as increasing but decreasing emissions by changing to a higher gear well before the box .
580 Nm and 60+ mpg is a nice combination to have.
